If you were to say that Insta360 is best known for its mastery of 360 cameras, action cameras, pocket cameras, and imaging in general, you definitely wouldn’t be wrong. (Did we mention our 360 technology even won an Emmy?!) However, you would be sorely mistaken in thinking that’s all we make.
Since our inception, our mission has been simple: to help people better capture and share their lives. And while capturing great visuals is a huge part of that, there’s another piece of the puzzle that’s just as important: sound.
A great video can be ruined by poor audio. A great story can lose its impact when dialogue is difficult to hear. And even the most impressive footage needs clear, natural sound to make you feel like you’re actually there.
That’s why we’re building an increasingly comprehensive audio ecosystem around the same principles that have shaped our approach to imaging: high-quality performance, intelligent technology, and simple, seamless workflows.
From cameras with increasingly capable built-in microphones to dedicated wireless microphone systems and AI-powered conferencing solutions, Insta360 is expanding its approach to capture beyond the image.
Insta360 Mic Series - Pro Audio for Creators
For casual users, the built-in microphones on Insta360 cameras can capture clear audio in a wide range of environments. But when audio really matters, a dedicated wireless microphone can make a huge difference.
That’s where the Insta360 Mic Series comes in.
Designed for content creators, vloggers, filmmakers, interviewers, and anyone who needs reliable audio on the move, the series combines high-quality recording with the convenience of wireless connectivity. Instead of worrying about complicated setups, tangled cables, or whether your audio will survive a challenging environment, you can focus on what you’re actually there to capture.
And with options ranging from lightweight everyday recording to more advanced professional setups, there’s a wireless mic for different types of creators and workflows.
Insta360 Mic Pro
At the top of the range is Mic Pro, a flagship wireless microphone for creators who want professional-level audio without a complicated setup.
Mic Pro combines premium audio hardware with intelligent features and extensive customization, making it suited to everything from interviews and filmmaking to events and multi-person shoots.
Its three-microphone array offers selectable omnidirectional, cardioid, and figure-8 pickup patterns, giving creators more control over how they capture sound. Mount it to a camera and it can even function as a shotgun microphone, adding another layer of versatility to the system.
When the environment gets noisy, NPU-powered AI noise cancellation helps isolate voices while maintaining natural-sounding speech. And for situations where you simply can’t afford to lose a take, Mic Pro supports 32-bit float internal recording, giving you significantly more flexibility when recovering audio levels in post.
There’s also 32GB of onboard storage, stereo internal recording, and support for scalable multi-channel configurations, including 4-to-1 and 2-to-4 setups.
Then there’s something you probably won’t find on many other wireless microphones: a customizable E-Ink display on each transmitter. It’s practical for instantly identifying transmitters, but it can also give your setup a distinctive visual identity.
In short, Mic Pro is built for creators who need their audio to keep up with increasingly complex shoots.
Whether you’re recording an interview, covering an event, working with multiple people, or switching between different cameras and recording setups, Mic Pro gives you the flexibility to adapt without adding unnecessary complexity.
Insta360 Mic
For those who want the customizability of Mic Pro, but at a lower price point, there's Insta360 Mic.
Mic is the ideal choice for YouTube collaborators, podcasters, and vloggers who need high-end audio without the flagship price tag. This model excels in scenarios where you need long-form recording, as the microSD slot allows you to expand storage indefinitely without offloading files mid-shoot.
Users will benefit from the same NPU-powered AI noise-canceling found in the Pro model, ensuring clean vocals even in busy environments. While it lacks the customizable E-Ink display, Mic remains a powerful, scalable solution that supports cross-generation connectivity with Mic Pro.
Insta360 Mic Air
Not every creator needs a professional multi-microphone setup. Sometimes you just want something small, light, and easy to use.
That’s where Mic Air comes in.
Weighing just 7.9g, Mic Air is an ultralight wireless lavalier microphone designed to disappear into your setup. It delivers 48kHz high-quality audio, built-in noise reduction, and up to 10 hours of battery life, while its 300m wireless transmission range gives you plenty of freedom to move.
It can be worn using its magnetic, clip-on, or pendant options, and direct camera compatibility makes getting started quick and straightforward.
That makes Mic Air particularly well suited to vlogging, travel, everyday content creation, and other situations where portability matters more than having an extensive professional setup.
In other words, if Mic Pro is designed to give creators maximum control,Mic Air is about giving you great audio with minimum fuss, and Mic is the all-rounder.
More Than Creator Microphones
The Mic Series is a major part of Insta360's approach to audio, but it isn’t the whole story.
As our products have expanded beyond cameras, so has the role of audio. Today, Insta360 also develops solutions designed to make communication clearer and more intelligent, from personal workstations to professional meeting rooms.
Insta360 Wave
Insta360 Wave takes our approach to AI-powered audio into meetings and hybrid work.
Instead of simply acting as a traditional speakerphone, Wave combines advanced microphone hardware with intelligent audio processing to help make conversations clearer. AI noise reduction helps cut out unwanted background sounds, while voice pickup technology is designed to keep speakers clear and intelligible.
For hybrid workers, remote teams, and anyone who spends a large part of their day in online meetings, the goal is simple: less time worrying about audio and more time communicating.
Insta360 Connect
For larger and more professional spaces, Insta360 Connect brings audio and video together in a single intelligent meeting solution.
By combining high-quality cameras, AI-powered framing and tracking, advanced voice pickup, and intelligent noise cancellation, Connect is designed to make professional video conferencing feel more natural and less dependent on complicated equipment.
From a solo creator recording a vlog to a team collaborating across continents, the scenarios may be different, but the underlying challenge is the same: how do you capture and communicate clearly?
One Audio Vision
From the Insta360 Mic Series to Wave and Connect, these products may be designed for very different situations. But they share the same underlying idea.
Great audio shouldn’t be complicated.
For creators, that means having a wireless microphone that can move with you, adapt to different environments, and capture professional-quality sound without slowing you down. For professionals, it means intelligent audio tools that make meetings and communication clearer with less manual setup.
And for Insta360, it means continuing to expand what it means to capture and share life.
We started with a focus on helping people see the world differently. Now, we’re making sure they can hear it clearly, too.
