Top 5 Ski Accessories
この記事の内容
この記事の内容
It's nearly that time. Temperatures are dropping, and crispness is in the air—ski season is approaching. If you live for the thrill of hurling down the side of a mountain at 70 mph, then you're probably getting excited, but epic ski runs deserve epic footage.
Don't be the person who tries to juggle a smartphone while zipping down a black diamond run. Here are five ski accessories every skier heading into the mountains needs this season.
The Essential Accessories Every Skier Needs
Before you clamber onto the lift for your first run of the day, you need the right kit to ensure a safe and enjoyable day on the slopes, allowing you to capture every twist and exciting turn.
Start with the basics: a solid helmet, anti-fog goggles, and waterproof gloves for all-day comfort. Layer up with breathable, moisture-wicking clothing to stay warm without overheating. And if you’re aiming for pro-quality footage, don’t forget a ski camera built to handle the cold and keep rolling through snow, speed, and wipeouts.
Ski Helmet with Mount Compatibility
Even if you're inching slowly down the bunny slope, your ski helmet is your best friend. Yes, you do see people without them, but research suggests that wearing a helmet reduces the risk of head injury by between 21% and 45%. The choice is yours, but think about that tree that whizzes past you in the blink of an eye, and don't think about slamming into it at 70 mph.
If keeping your brain in one piece isn't enough, helmets also provide the foundation for stable, jaw-dropping POV footage. Forget holding onto a camera; simply mount it on your helmet and get ready for the ride of your life that provides that true first-person perspective—like your viewers are right there in your goggles.
Pair it with the lightweight, cold-resistant Insta360 X5 for ultra-smooth 360 footage and never have to do those annoying retakes or additional angle shots. Game. Changed.
Waterproof Ski Gloves with Grip
As soon as the hands begin to freeze, it's only a matter of time. Cold hands can ruin a perfect day, so you'll want to invest in a pair of waterproof, insulated ski gloves that keep your fingers warm, dry, and nimble enough to adjust bindings, zip pockets, or hit record without fumbling.
Modern ski gloves use Gore-Tex or similar membranes to block moisture while letting sweat escape—crucial when pushing hard on the slopes. Also, go for gloves with a strong grip and touchscreen-friendly fingertips to control your camera or phone without taking them off.
Anti-Fog Ski Goggles with Polarized Lenses
There’s a saying on the slopes: ‘If you can’t see, you can't ski.' OK, we might have made that up, but it's so true it should be on a bumper sticker. Fogged-up goggles are every skier’s nightmare, so think about anti-fog goggles with polarized lenses that keep your vision clear and colors true, no matter the conditions.
It’s one area where investing a little money really pays off. Yes, you can get a $20 pair of goggles from Walmart, but the vision standard will likely be appalling. Pay more and get goggles with dual-pane lenses, anti-fog coatings, and good ventilation. Polarized or photochromic options reduce glare and help your camera capture more natural color balance on bright, snowy days.
Compact Ski Camera for Pro-Level Footage
You can have the best gear on the mountain, but if you’re not capturing it, did it even happen? A ski camera is the ultimate accessory for documenting your runs and reliving every carve in stunning detail, and with Insta360, you're spoilt for choice.
Models like Insta360 X5, Insta360 X4, and Insta360 Ace Pro 2 deliver cinematic footage with buttery-smooth stabilization and crystal clarity, even at high speeds. Insta360 X4, with its 8K 360 capture, lets you film now and reframe later—perfect for getting multiple angles from one shot. Or, mount your Insta360 Ace Pro 2 on your helmet for that first-person thrill, or use a chest or pole mount for dynamic follow-cam shots.
Ski Backpack or Mounting System
When you’re skiing with camera gear, how you carry it matters as much as what you’re carrying. A good ski backpack keeps your essentials organized, balanced, and protected from snow and impact. You also don't want your sandwiches falling out and being run over by a skier behind you. Nobody likes that.
Look for lightweight, weatherproof packs with easy-access compartments and padded camera pockets. Compression straps and hydration compatibility are nice bonuses when you’re on long runs or shooting all day. For creators, a mounting system can turn your pack into a mobile rig.
Shoulder or back-bar mounts capture immersive follow shots, while extendable selfie sticks (like Insta360’s Invisible Selfie Stick series) make it look like your camera’s floating midair. Obviously, this might be overkill for the average skier who just wants to record their wintery exploits, but whatever you're looking for, there are options.
What Are the Must-Have Ski Accessories for Beginners?
Start simple—safety first. A reliable helmet, anti-fog goggles, and waterproof gloves are your go-to essentials. Then add a compact and easy-to-use camera like Insta360 X4 to document your early runs.
How Can I Record My Skiing Adventures Safely?
Secure your camera with a helmet, chest, or pole mount to keep your hands free and your shots stable. Always double-check your mount before you start your run—and keep your gear tethered in case of a fall.
What Gear Improves Skiing Performance in Cold Weather?
Layer up. Breathable, insulated clothing keeps you warm without restricting movement. Add moisture-wicking base layers and waterproof outerwear to stay dry. Accessories like anti-fog goggles and heated gloves make a noticeable difference when temperatures drop below freezing.
Are Ski Cameras Worth It for Casual Skiers?
Absolutely. Today’s ski cameras are compact, lightweight, and simple to use—even if you’re not a pro. With 360 capture and smart editing tools, cameras like Insta360 X4 let you relive your runs from every angle and share them instantly. It's ski footage like you've never seen before.
Ready to Capture Your Skiing Adventures with Insta360?
For some, the call of the mountains grows eagerly through fall and into early winter. They check forecasts, do snow dances, and hope, above all, for that first big storm of the season to arrive, leaving the ground a brilliant white. It's time for ski adventures to start once again.
The right ski accessories can make or break the experience. When things become too risky, cold, wet, or fogged up, it stops being fun. From protective gear that keeps you comfortable to cameras that capture every carve and crash in stunning clarity, the right setup helps you ski smarter and film better.
So pack your bag, clip in your Insta360 camera, and prepare for the run of your life. Ski season is here. Hold on tight.
登録済ですか?
購入サポート
購入前の質問 注文と支払い 返品と返金
icon営業時間:10:00-19:00(GMT+9)
製品サポート
トラブルシューティング・ヘルプ 保証・修理サービス
