While the right location/background, topic, and on-camera personality are important for vloggers, the audio can make or break the success of your vlogs. Your audience won’t tolerate poor audio, so investing in a high-quality mic makes sense.
There are plenty of wired mics, but wireless options offer much more flexibility and portability, and are great for those who want to vlog on the go without being tethered to their computer or other devices.
This guide goes over what you should keep an eye out for when deciding which wireless microphone to pick up for vlogging.
What Is a Wireless Microphone for Vlogging?
A wireless microphone for vlogging is a compact and battery-powered mic that lets people record audio, even when they’re far away from their camera or other device. These often consist of a transmitter with a built-in mic that captures the audio, as well as a receiver that receives the audio and sends it to the recording device, such as your computer or phone.
Types of Wireless Microphones Used by Vloggers
Whether you’re just starting a vlog or looking to take your current vlog audio to new heights, it’s important to know the kinds of wireless microphones you can use. Some of the most common options include:
- Lavalier microphones: These are small, discreet and lightweight mics that clip to clothing, are worn like a pendant or stay in place with a magnet. They stay fairly stationary and are close to the subject, so they provide consistent and quality audio, even in loud areas. Their hands-free design also allows freedom of movement.
- Shotgun microphones: A shotgun microphone is a directional tube-shaped mic that often mounts to a camera or a pole, and captures the audio in front of the mic, while suppressing and reducing the audio off to the sides.
- Wireless handheld microphones: Wireless handheld mics are easy to pass from one subject to another quickly and are generally quite durable. They’re also great for isolating the subject’s voice from the environment.
- Wireless desktop microphones: If someone mainly makes stationary vlogs where they sit at their desk or a table, a wireless desktop mic on a stand is a popular choice. This is similar to a wireless handheld mic, except that it sits on the desk in a stand to allow for hands-free usage.
Key Features That Matter When Choosing a Wireless Mic for Vlogging
When you're choosing a wireless mic for your vlog, some features you should look for include:
- High-quality audio: The mic should capture true-to-life sound, have a high sampling rate, and the right pickup pattern to capture the subject’s voice while minimizing ambient noise. It should also have noise reduction features, especially if you’re filming vlogs in public or anywhere that may get loud. If you're looking for professional-grade audio quality without adding unnecessary complexity to your setup, Insta360 Mic and Mic Pro are designed for creators who demand cleaner voice capture, advanced noise reduction, and reliable wireless performance. They delivers broadcast-quality sound while remaining compact enough for everyday vlogging.ing.
- Battery life: Poor battery life can interrupt the filming process and leave you tethered to a power source, much like using a wired mic. As a result, choose a wireless mic with strong battery life, preferably 10 hours or more, so you can use it for day-long shoots without stopping to recharge. Insta360 Mic offers up to 13 hours of battery life and can even extend up to 34 hours with the charging case.
- Design: The design, size, and shape of the mic also matter. It should be light enough to use for long periods without being annoying or heavy, small enough to carry around easily, and, if it’s a lavalier mic, offer many different ways to attach it to suit different needs or scenarios.
Also, if you’re clipping the mic to clothing, choose a color that is easy to match with the clothes, such as black, grey, or white. This helps it be less noticeable in your vlogs.
- Range: Choose a mic that offers enough range for your needs, as well. If you’re a stationary vlogger, most mics should suffice, but if you’re a travel vlogger or livestreamer who may be far from the camera at times, a long-range mic offers much more freedom of movement and keeps the audio high-quality and consistent.
Device Compatibility and Connectivity You Should Check Before Buying
Of course, before you buy a wireless vlogging mic, you need to check for compatibility and connectivity. The last thing you want when you’re about to film a vlog or fire up a livestream is to learn that the mic you bought isn’t compatible with your camera, phone or other device.
Make sure any wireless mic you buy has the proper connections and is compatible with what you plan to use to record your videos. For example, if you buy a wireless mic with a receiver that has a Lightning connector, but the Samsung phone you’re filming with has a USB-C port, the pair may not work together.
While many cameras may offer interchangeable adapters that work with any port, this isn’t always the case, so make sure to check. Most online product descriptions or photos should give you an idea of the type of connections a mic has, and which kind of devices it’ll work with.
Also, if you plan on mounting the mic to a camera or other device, ensure it has the proper mount that matches the requirements of your camera. If not, it may not attach at all, or even if it does, it may be a loose connection that could lead to dropping or damaging the mic.
However, keep in mind that just because two devices don’t directly connect doesn’t mean you automatically can’t use them together.
For example, while you can’t directly connect a mic like Insta360 Mic Air to Insta360 Link 2, as the camera doesn’t have an external audio input port, you can connect both to your computer and use Insta360 Link 2 as your camera and Insta360 Mic Air as your audio output device.
How Wireless Microphones Work in Real Vlogging Scenarios
In real-life vlogging scenarios, wireless microphones let vloggers move freely throughout the shot, while still maintaining high-quality audio, even as they move away from the camera. These bypass the onboard mic on the camera or phone and offer much better audio. Here’s a breakdown of how they actually accomplish this.
First, the mic transmitter (the part of the mic that you clip to your clothing, if you’re using a lavalier mic) converts the audio it captures into radio frequency signals. Next, it transmits these signals to the receiver, which often plugs into your phone or camera, or is integrated into the device itself.
Finally, the receiver gets these signals and converts them back into audio signals, and feeds the audio right to the recording device.
Why Wireless Microphones Are Better for Modern Vlogging
Wireless microphones are normally a better choice than wired mics for modern vlogging for a variety of reasons. First, they provide a ton of flexibility and creative freedom compared to wired mics, as they work just as well when you’re vlogging at your setup or doing a travel vlog in the mountains.
Many wireless mics also allow for hands-free talking on camera, which often looks more natural and professional than holding a wired mic. These mics are also easy to set up, often offer built-in noise cancellation features for great audio quality, and have plenty of range.
Using discreet wireless mics may also improve your videos in general, as there won’t be distracting cables moving throughout the screen, which can distract your audience and make videos look less professional.
Also, if you’re filming videos where you move around a lot, such as fitness, cooking, or adventure vlogs, going wireless reduces the chances of you tripping on cables and accidentally unplugging something important or hurting yourself.
Choosing a Wireless Microphone Based on Your Vlogging Style
An underrated thing to consider when choosing the right wireless vlog mic is your vlogging style. The perfect mic for one vlogger may be a terrible choice for another.
If you’re always on the move or recording driving vlogs, you may want to go with a small and compact mic that’s easy to transport. You also need to consider the battery life, as well as noise cancellation, to reduce background noise like vehicles, machinery or other people as you’re vlogging.
If your vlog content involves interviewing people, or you’re part of a two-person vlogging team, it makes sense to go with either a dual-transmitter system or a wireless handheld mic that you can easily pass from one person to another.
Travel or action sports vloggers need a mic that’s durable and offers sweat protection or is waterproof. Because of the constant movement involved, you should also look for one that always stays in the right place, either with clips or magnets.
Of course, if you change up your content often and do different kinds of vlogs, consider a versatile wireless mic that offers many of the features mentioned here.
Why an Integrated Creator Ecosystem Makes Audio Easier
If you’re looking to make handling your vlogging audio that much easier, consider using an integrated creator ecosystem, such as Insta360. These ecosystems often offer straightforward hardware integration, so you won’t need to worry about devices not being compatible or experiencing connectivity issues.
For example, Insta360 Mic Air can connect wirelessly to cameras like Insta360 X5 or Insta360 X4, without needing a receiver, making it one of the best Insta360 X5 accessories for creators using the camera.
There normally won’t be any complex setup process, technical hurdles, extra adapters or issues syncing video to audio if you stay in an integrated creator ecosystem, either.
Also, integrated creator ecosystems may go beyond just audio and help with other aspects of your vlog, such as cloud backups for footage, editing tools, and instant sharing to socials or via messaging apps.
Which Wireless Microphone is Best for Vlogging?
Insta360 Mic Air is one of the best mics for vlogging, thanks to its compact size, 10-hour battery life, and large wireless range. There are also several ways to wear it, and the mic is incredibly light. It also has advanced noise cancellation, so your voice is always clear, and lets you control things like mute and noise cancellation right from the transmitter.
What Features Should I Look For in a Vlogging Mic?
When searching for a vlogging mic, some features you should watch for include high-quality audio, noise cancellation, a compact size, and a lightweight design. It should also offer multiple mounting choices and versatile output options. Finally, make sure it’s durable and well-made if you plan on using it for travel or outdoor/adventure-related vlogs.
What Factors Should You Consider When Choosing a Microphone?
Some of the most important factors when choosing a microphone in general include the build quality, the sensitivity, your budget, the space(s) you’ll generally be using it, the connection type and the microphone pickup pattern it uses.
How Many Hz is Good for a Microphone?
While the exact best frequency response depends on what you’re using the mic for, a frequency range of 20Hz to 20kHz is generally good for a microphone. This is because this range is enough to cover the full range of human hearing, ensuring your vlog’s audio is natural and all sounds are properly captured.
Upgrade Your Vlogging Audio with a Smarter Wireless Mic Setup
Upgrading your vlog audio by using a high-quality wireless mic can help your vlogs appear more professional, keep viewers around and may offer a more immersive viewer experience.
When considering a wireless mic for vlogging, find one that offers high-quality audio, a long battery life, solid range and the right shape and design for your needs. If you’re looking for a versatile wireless vlogging mic, consider Insta360 Mic Air. It provides plenty of battery, 48kHz high-quality audio, and simple controls, all packed into a light and compact form factor.
