3 Best Underwater Cameras in 2026
You only get one shot at capturing what lives below the surface. Colors fade, memory drifts. With a dive camera in hand, you freeze the moment. You bring home proof of what you saw, how it moved, what it felt like to be there. For many, it’s the closest thing to reliving a dive.
Whether you're drift diving or exploring coral walls, the best scuba cameras let you document your entire journey—hands-free, without missing a beat.
How to Choose an Underwater Camera
Not all cameras for scuba diving are built the same. Before you commit, consider what matters most:
  • Waterproof rating: 33ft is great for snorkeling, but deeper dives need more.
  • Low-light capability: Light drops fast below 33ft (10m). Better sensors make a huge difference.
  • Battery life: Longer dives need longer runtime.
  • Stabilization: In-camera stabilization smooths out jerky underwater footage.
  • Video resolution: 8K is ideal for capturing all the beautiful details from your dive.
  • Mounting flexibility: Look for systems that work with dive accessories like floating grips or stick mounts.
Two divers swimming underwater.
Dive Camera Price
Dive camera prices can vary significantly based on features, depth rating, and image quality. Entry-level models suitable for casual snorkeling or shallow dives start at around $100. More advanced options with 4K video, image stabilization, and waterproof housings rated for deeper depths typically range from $400 to over $1,000. High-end setups, including professional cameras with interchangeable lenses or action cams with premium accessories, can cost even more.
So, how much does it cost to capture high-quality underwater footage? Here’s a quick breakdown:
  • Budget range (under $400): Insta360 Ace Pro, Insta360 X4
  • Mid-tier ($400–$500): Insta360 Ace Pro 2
  • Flagship ($500+): Insta360 X5
You don’t always need the most expensive option — the key is understanding what each camera does best and choosing one that fits your needs and diving goals.
Best Overall Underwater Camera for Diving
Insta360 X5
When you want top-tier results without compromise, Insta360 X5 is the one to beat. With 8K 360-degree video, it captures everything with clarity, stability, and detail that holds up even in the toughest underwater conditions. This is the best scuba camera for divers who care about every pixel and every frame.
From night dives to complex reef environments, the X5 brings low-light performance that makes other cameras struggle to keep up. PureVideo Mode uses AI denoising to clean up shadows and boost image quality in dim water. Plus, the battery lasts longer than any other camera on this list.
Benefits of Insta360 X5 for Diving:
  • Exceptional low-light clarity—ideal for deeper dives and dusk conditions
  • PureVideo Mode delivers cleaner footage in challenging lighting
  • With 185 mins of battery life (in Endurance Mode), Insta360 X5 records longer than any other Insta360 camera.
  • Replaceable lenses mean you do not need to worry about scratches or damage from regular use.
  • 8K 360 capture gives you total freedom to reframe your shots after the dive
  • Invisible Dive Case support takes it to 197ft with smooth, accurate stitching
If you want cinematic underwater content and total creative flexibility, Insta360 X5 is your best bet.
Best Budget Underwater Camera
Insta360 X4
Budget shouldn’t mean basic. Insta360 X4 delivers standout results without asking for much in return. It’s the kind of scuba camera you can rely on day after day—ready to shoot as soon as you hit the water.
You get sharp 8K 360 footage, reliable waterproofing, and stabilization that holds steady in current or surge. It’s easy to pack, quick to set up, and does the job without complication. For divers looking to gear up without going overboard, this is the smart pick.
Benefits of Insta360 X4 for Diving:
  • Makes 360 video simple—even for first-timers
  • Tough enough to take bumps, drops, and salty conditions
  • Works great out of the box—no extra gear required for shallow dives
  • Saves time in editing with Auto Frame and AI-powered reframing
  • Long battery life means fewer interruptions underwater
Want to go beyond 33ft? Just add the Invisible Dive Case. It extends the camera’s reach to 164ft while keeping your footage stitch-ready and clear.
Best Underwater Camera for Beginners
Getting into underwater shooting doesn’t have to feel overwhelming. Insta360 Ace Pro 2 strips away complexity and puts intuitive tools in your hands. Insta360 Ace Pro 2 is sharp, smart, and very stable—perfect for capturing dives with minimal fuss.
The camera is ready when you are. Flip out the screen, adjust nothing, and start shooting. Gesture control lets you operate hands-free, and built-in stabilization smooths out any unintentional movement. Plus, with a Leica SUMMARIT lens, 1/1.38” sensor, and PureVideo Mode for excellent shots even in low-light, you get professional-looking results, even if you're just starting out.
Benefits of Insta360 Ace Pro 2:
  • Leica optics and specialized low-light mode for clear footage at depths
  • Simple interface makes setup fast and stress-free
  • 2.5” flip screen helps you see your shot clearly before pressing record
  • Smart exposure and HDR mode adapt to shifting underwater light
  • Gesture control means no fumbling for buttons
  • Compact design travels easily and mounts anywhere
Whether you're snorkeling with turtles or testing scuba for the first time, Insta360 Ace Pro 2 helps you capture it all, without needing to be a tech expert. Learn more in our Scuba 101 blog.
Comparison Table – Specs & Key Features
CameraBest ForWaterproof Depth (w/out case)Max. ResolutionBattery LifeKey Feature
Insta360 X5Low light, Pro 360 content49ft (15m)8K30fps 360185 minsPureVideo, Replaceable Lens
Insta360 X4Best value, all-purpose diving33ft (10m)8K30fps 360135 minsFlowState Stabilization
Insta360 Ace Pro 2Image quality, Leica optics39ft (12m)8K30fps85 minsDual AI Chip, Flip Screen
Insta360 Ace ProSimplicity, improved software33ft (10m)8K24fps75 minsActive HDR, Budget Friendly
How to Get Started With Underwater Photography
Underwater photography isn’t complicated, but it’s not like shooting on land. The key is in how you prepare. Most problems can be avoided with a good setup and a few smart habits.
Start simple. Get familiar with your camera on land first—test the modes, understand how buttons respond, and learn how to frame a subject. Practice makes perfect.
Then take it slow. Rushing leads to blurry shots and missed focus. Underwater, smooth movement isn’t just aesthetic—it’s necessary.
Confidence comes from repetition, so make your first few sessions short and focused. Shoot in shallow, well-lit areas. Use Auto mode. Learn how your camera behaves in real-world conditions.
Keep these points in mind:
  • Use an Invisible Dive Case for X5 or X4 to avoid stitching errors.
  • Switch on Dive Case Mode before entering the water.
  • Remove non-waterproof lens guards before any dive.
  • Stick to Auto Mode if you're just starting out.
  • Carry anti-fog inserts and rinse gear post-dive.
For lighting, position yourself with the sun behind you to keep your subject well-lit and clearly visible. If you're in low-light conditions, especially deeper dives, use PureVideo Mode on Insta360 X5, Insta360 Ace Pro 2, or Insta360 Ace Pro.
Recommended Dive Accessories
To get the most from your scuba camera, pair it with the:
Shooting Tips and Settings
  • Insta360 X5: Use 8K30fps or PureVideo in darker conditions. Set bitrate to "High."
  • Insta360 X4: Shoot 8K in shallow light, 5.7K deeper.
  • Insta360 Ace Pro 2: Go with Active HDR or PureVideo. Keep sharpness on Medium.
  • Insta360 Ace Pro: Stick to 4K60fps. Use Active HDR for contrasty scenes.
Avoid fast movements. Keep a straight camera-to-subject line when using the Invisible Selfie Stick. Edit later in the Insta360 app with AquaVision 2.0 for color correction.
Post-Production & Sharing
Once you've surfaced, bring your footage to life:
  • Use Quick Edit or AI Edit in the Insta360 app for easy reframing.
  • Export 360 clips in original resolution.
Recommended export settings:
  • YouTube: 4K, H.264 or H.265, 65–80Mbps
  • Instagram: 1080x1350, mp4, 13–15Mbps
  • TikTok: 1080x1920, mp4, 13–15Mbps
Choosing the best underwater camera depends on what matters most to you: resolution, size, price, or how far down you plan to go. If you're looking for the latest flagship 360 camera, then you want Insta360 X5. If you want a budget-friendly option, Insta360 X4 is an excellent choice. For those who prefer a more traditional perspective, Insta360 Ace Pro 2 packs pro-grade performance into a small frame.
Every dive is different. Make your next one unforgettable.
Keen to keep up to date on Insta360 stories? Keep an eye on our blog and sign up for our mailing list. Got a story to share? Email yours to communitystories@insta360.com and win up to US$50.
